Message 11 of 16
Re: Youview and Youtube
@Jge46 wrote:
So, the box will work over a wifi link.
@Jge46
I think you will find that the TP-Link devices use the mains wiring to carry the Ethernet signal, just like the BT minihubs. They extend Ethernet, and generate a local wireless hotspot.
The YouView box is therefore connected by Ethernet not wireless.
Message 12 of 16
The unit I I have is a TP-Link TL-WA860RE.  It is  a single unit, there is nothing connecting the hub to the power supply.
The set up provided me with the usual terrestrial tv stations along with pause/rewind and unormal catch-up facilities.   There may be additional services which require multicast, possibly their chargeable offerings which I wouldn't use.
Message 13 of 16
It will work with non-multicast services, its multicast that causes the problems.
Message 14 of 16
Just out of interest, what are the multicast services? Cheers
Message 15 of 16
All of the ones that form part of the BT extra channels subscripton.
Message 16 of 16
That's OK then, I just wanted the basics rather than subscription channels So I guess I'll stick with my wifi solution.
thanks for your help
