Message 1 of 7
Youview box broadband light
My bt youview won’t connect to broadband. Power is on but not broadband. I am using an Ethernet cable between hub and youview. My I have switched both router and youview on and off for a while. Broadband is ok to phone via wireless.
6 REPLIES 6
Message 2 of 7
Re: Youview box broadband light
@Carpetbagger1
Try a different Ethernet cable.
Also check that the Ethernet cables are secure both ends, and the securing clip is not broken, as that is a very common cause of problems, as without the plug clicking into place, and being help by the clip, you will get a bad connection.
Message 3 of 7
New Ethernet fitted, box says waking up & wait. Should the broadband light be on at this stage ?
Message 4 of 7
Still no light, just keeps going through same process , wake up, wait , youview logo & wait
Message 5 of 7
It should still start up, even if there is no Ethernet connection, so it sounds like the box is faulty.
See if anyone else has any suggestions.
Moderator
Moderator
Message 6 of 7
Hi Capetbagger1 I'm sorry to see you're having problems with your Youviewbox. Can you try a factory reset choosing the option to keep your recordings? Post back and let me know if this helps?
Message 7 of 7
Hi, I had on line chat with bt faults and they asked me to try a few things without success. They are now sending new box out to me
