Message 1 of 3
Youview box broke
  • Hi, youview box failed last night. Kept beeping and now stuck on boot loop. Tried the reset but no luck. What happened next? Thanks in advanc
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Youview box broke
Hi @Tri99s
Assuming you have a current BT Tv subscription  ringing 150 or 0800 800 150 and reporting it as a TV fault.
It will probably require replacement as the beeping suggests a problem accessing the box harddrive.
Message 3 of 3
Is there anyway it can be resolved without a phone call. Don't want to add to the phone queues for a non urgent issue.
