Ekmcd
Newbie
Message 1 of 3
Youview box connecting to Smart Hib
I've just had a new smart Hub 6 delivered and tried to connect my youview box via cable. I have turned off smart setup. The youview box is sensing the connection but is not allowing me to access any functions...any clues please?
Tags (1)
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Youview box connecting to Smart Hib
@Ekmcd Welcome.
is the Youview box also new or have you been successfully using it previously with other HomeHub or routers ?
BT TV Expert
BT TV Expert
Message 3 of 3
Hi @Ekmcd
Sorry to hear you are having issues with the smart hub. If you send me your telephone number via PM I will take a look into the issue for you.
Thank you.
