Message 1 of 3
Youview box entering standby
I have a BT Youview DBT2200, and have smart standby enabled as below -
auto standby 12hours
start deep sleep 1am
end deep sleep 7am
i turned off my tv about 8.15 this morning then ive had the tv on again tonight from about 6.15 and its just flashed up a message to say the box is about to enter standby, after about 1hr 15mins??
This has happened a few times, why though as auto stanby is set to 12 hours??
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Youview box entering standby
Are you perhaps only switching off your TV set and therefore leaving your Youview box on in the mornings.
Message 3 of 3
I only switch the tv off, so the youview box would have been idle for approx 10 hours, from 8.15 to 6.15, then i would have changed channel or viewed the epg upon viewing the tv then therefore "restarting" the autostandby time??
