jake1000x
Newbie
Message 1 of 5
Youview box is causing panasonic TV to go into standby
I have just recently bought a Panasonic TX-40CX400B. I have a BT youview set top box in HDMI 1. Randomly the youview causes the TV to go into standby. I don't think it is a problem with the power for the TV, as i put it onto TV mode and left it while i went to work. When i came back the TV was still on. I then turn the youview box on and switch to HDMI, the TV will then randomly go to standby. This can happen from 5 minutes to a couple of hours. Really confused, tried a new BT box and still the same thing happens.
4 REPLIES 4
gomezz
Recognised Expert
Message 2 of 5
Re: Youview box is causing panasonic TV to go into standby
Turn off CEC on the TV (not sure what it is called on a Panny).
jake1000x
Newbie
Message 3 of 5
just tried that. still going into stanby.
Distinguished Guru
Message 4 of 5
Do you have another hdmi socket on the tv you could plug the youview box into?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
jake1000x
Newbie
Message 5 of 5
Got rid of TV, new samsung has no problem.
I tried a new HDMI port, lead and even a new youview box, but  nothing was soloving my problem. The TV started turning itself off even when on using the xbox one, must of been a fault on the TV.
cheers anyway.
