mikemoyes1987
Message 1 of 6
Youview box loud fan noise
Last week I received a new 4K BT box, I previously just had the normal recording one.
It's making a quite a loud noise bit like the fan overworking, is this normal or do i contact support?
5 REPLIES 5
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 6
Re: Youview box loud fan noise
Well the DTR2100 doesn’t have a fan whereas the DTR4000 does so it’s understandable that there would be a difference in fan noise.
is the fan on constantly  ?
How is the box positioned , is there plenty of air flow or is it stacked or enclosed ?
mikemoyes1987
Message 3 of 6
i would say majority of the time it is, it's in a flat position with air flow and no stacking
TimCurtis
Guru
Message 4 of 6
@mikemoyes1987
You could perhaps try temporarily standing on some form of sound absorpent material to see if that helps.
gomezz
Recognised Expert
Message 5 of 6
A cloth dinner mat is good for this.
(I use them under my surround sound speakers where they are sitting on a glass shelf
mikemoyes1987
Message 6 of 6
I used a mouse mat and that worked, many thanks for the replies
