Keithr2
Message 1 of 4
Youview box return
Cancelled BT Sport and TV yesterday, because of price increase without charge. Advised I would have to return youview box. I have had the box since November 2017, I understand t and c's were changed after 13th Dec 2019 and as I have had box prior to that I will not be returning item.
3 REPLIES 3
Les-Gibson
Recognised Expert
Message 2 of 4
Re: Youview box return
As you received the box before 13/12/19 then, as you say, you are not obliged to return it unless you received a replacement after that date (due to a fault maybe?), however BT have a legal obligation to offer you a recycling facility.
                                                     If the Smart Hub 2 is BT's best hub yet then what does that say about its predecessors ?
Tags (1)
Keithr2
Message 3 of 4
Thanks for info. Hopefully BT will accept the situation.
TimCurtis
Guru
Message 4 of 4
@Keithr2
Just remember that you are within your rights to keep it.
If there turns out to be an issue come back & we can get the BT mods involved to sort it for you. They're very good at resolving issues.
