ACJMY2K
Message 1 of 3
Youview box will not turn on without reset
We had an issue recently with missing channels, so we had a replacement 4k YV box provided.
Now, the box will not turn on in the morning unless I turn off the plug first. I've hard reset the box, reset the remote and also changed power settings so it's always on (purple light).
Once it's on, it's fine all day without issue but its just that I have to reset it everyday before it will turn on.
2 REPLIES 2
JohnC2
Moderator
Moderator
Message 2 of 3
Re: Youview box will not turn on without reset
Hi @ACJMY2K welcome to the forum and thanks for your post. I've not come across this before but it may be to do with the standby mode. Check out what mode you are on and see if changing it to one of the other options resolves the problem? BT TV standby modes and how to manage them.
cheers
John
ACJMY2K
Message 3 of 3
Thanks yeah I thought this too - it was on smart so I changed it to 'always on' but the problem still occurs
