Robert77
Newbie
Message 1 of 4
Youview+ box
I have a youview + 500gb box model name
dtr t2110/500gb/bt/hs
Model code 91-00512
The box was cycling between loading without ever getting to a usable state. I have entered maintenance mode and tried all the options;
Software reset, factory reset and internet/usb recovery using both keep and delete recordings. Is there anything else I can do. Is there a usb stock file?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Youview+ box
Hi @Robert77
Thanks for posting sorry you are having problems with your youview box.
From your post I'm not sure if this is a Youview box as part of a BT TV subscription or one purchased on the high street. It does sound like there is a fault with the box.
Stuart
Robert77
Newbie
Message 3 of 4
Re: Youview+ box
It was purchased on the high street over a year ago I think.
Message 4 of 4
Re: Youview+ box
Then BT would not be able to help with this issue, if its a faulty box.
