Message 1 of 5
Youview error BTP-15000
My youview box is displaying BTP-15000.
I've seen post on here that the mods are able to resolve this?
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Youview error BTP-15000
Hi @W4llac3 and welcome.
I'm sorry you're having problems with the BTP-15000 error message .
Can you try the following steps to try and fix these BT TV errors:
  1. Reboot your TV box by flicking the switch at the back
  2. Retry the service
  3. If you're still having an issue please get back to me.
Cheers
David
Message 3 of 5
Hi Dave,
It appears I've had this for awhile. I also checked if the box required a update, which it did.
I've updated and restarted, same issue.
Moderator
Moderator
Message 4 of 5
Thanks for getting back so quickly @W4llac3,
We'll need to take a closer look at this. I've sent you a Private message explaining how you can contact the forum moderation team. Check here: https://community.bt.com/t5/notes/privatenotespage. Please drop me a reply with the details and we'll take it from there.
Cheers
David
Moderator
Moderator
Message 5 of 5
Hi @W4llac3,
Thanks for giving me some time to work on this fault.
I'm glad to hear that the fault is now fixed after the latest changes we made in the background.
Matt
