Zombie
Expert
Message 11 of 12
Re: Youview iplayer buffering
Hi @jennifer328 the iplayer app must be have a glitch on it. I would try turning the power off to the tv box for a couple of minutes. It's surprising how many things can be fixed with the old faithful method of unplugging leave for a couple of minutes then plug back in.
Failing that you might have to try the factory reset but would result in loosing any of the recordings on the box.
jennifer328
Message 12 of 12
I switched everything off yesterday.   Router, tv everything.   I've sent a complaint to the bbc.   Will keep you informed.
Can't see a factory reset of the humax box working, as 4 and ITV have been ok tonight, so it doesn't appear to be the box, as far as I can tell.
