Drumlegend
Message 1 of 7
Youview not connecting to internet after turning on Home Hub
Whenever I go to work I always turn the home hub off and leave tghe youview box in case it's recording something. The issue is that when I turn the hub on when I get home the Youview box never connects to the internet unless I unplug the ethernet cable and re plug it back in. Does anyone know a fix for this. Not "leave your hub on all the time".
I don't feel comfortable leaving it on all day.
6 REPLIES 6
jparnell82
Message 2 of 7
Re: Youview not connecting to internet after turning on Home Hub
I occasionally have this with my youview boxes when something has happened to the homehub. Try assigning a static IP address to the youview box rather than the default dhcp and see if it helps.
JohnKelly
Message 3 of 7
Static IP Address. It seems to fix it. I did it to mine and it's absolutely fine. I set the IP address to be the max in the subnet that's allowed - 192.168.1.253 - and then set the hub DHCP as custom finishing at 192.168.1.252 so it would never allocate that particular address. Did it months ago so not sure whether you need to set other things on the hub like the gateway address which is 192.168.1.254 and the subnet mask which will be 255.255.255.0
I did this after having the same problem but mine was due to the home hub perpetually restarting itself.
Drumlegend
Message 4 of 7
I tried this last night you see and it connected but the on demand wouldn't work. Turned it back to auto and it did. Maybe I did something wrong but it did say it was connected.
Drumlegend
Message 5 of 7
12:32 PM
Add Commen
JohnKelly
Message 6 of 7
Strange - I did mine months ago and have never had any issues.
Drumlegend
Message 7 of 7
It works now after using a static up. Thanks guys.
