MrJolly
Message 1 of 14
Youview often crashes while streaming since upgrade to ultrafast fibre plus
Hi
Since 'upgrading' my broadband I've been getting a lot of issues using streaming on my BT youview box.
When using Catchup / iPlayer / Netflix I can rarely get through a whole episode without the youview box losing its connection. Symptoms vary:
1) Loss of sound, then freezes about 10 secs later
2) Blank screen
3) Occasional YMV104 error messages.
Generally worked around by increasing escalations through
1) Restart youview box
2) In youview settings, reconnect to router
3) Hard reset of youview box
LAN connection from youview to router via powerline adapter, identical to before router upgrade. Picture quality very good when its working.
No issues with wifi broadband connections when the youview errors occur.
Generally good broadband speed - last check was 86 mb/s download, 27 upload. (although this doesn't meet the guaranteed 100 download speed and I should be claiming my £20).
Can a moderator please assist? Can I get a replacement youview box please?
Richard
13 REPLIES 13
Moderator
Moderator
Message 2 of 14
Re: Youview often crashes while streaming since upgrade to ultrafast fibre plus
Hi @MrJolly  sorry that you have been experiencing problems with your BTTV service since you upgraded your broadband service. When did you upgrade? and did the errors only start when you upgraded.
It may not be the Youview box at fault. To help diagnose the fault is it possible for you to connect from the hub to Youview box via Ethernet?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
MrJolly
Message 3 of 14
Hi John
Broadband was upgraded 6th March.
I've noticed a lot more of these connection errors since then, had them very rarely previously.
I'll try with an ethernet connection but doubt it will make any difference.
What's the next step with diagnosis?
Richard
Moderator
Moderator
Message 4 of 14
Hi @MrJolly ,
Thanks for the reply. Getting to the bottom of this will be a step by step process, the first of which would be to try the Ethernet connection. Once you’ve done that let us know and we’ll take it from there.
Cheers
David
Community ModeratorDaveM
Kudos”
MrJolly
Message 5 of 14
Hi there
I've got my BT TV box connected via ethernet cable directly to the router now, this hasn't made any difference.
Also I noticed that the problem is  worse on Sunday evenings.
I was streaming iPlayer content on Sunday 7-9pm and had a least 4 instances of the issue.
Please advise next steps?
Many thanks
Richard
Moderator
Moderator
Message 6 of 14
Hi @MrJolly
Thanks for posting back and connecting the Youview box directly to the hub via ethernet.  Sorry you're still seeing the symptoms.
Can you run a speed test here?  http://www.speedtest.btwholesale.com/ with a device connected to the Hub via ethernet and post and screen shot of the result?  (Remember to choose "further diagnostics" after the first tests completes to run a more in depth test).
Whenever you have posted back we'll take it from there.
Cheers,
Robbie
Community ModeratorRobbieMac
Kudos”
MrJolly
Message 7 of 14
Screen shots of speed test from LAN-connected laptop attached.
Colin_London
Recognised Expert
Message 8 of 14
You have (unwittingly?) posted your phone number in one of the screenshots. Suggest that you remove that particular one!
MrJolly
Message 9 of 14
Thanks Colin I guess you edited that for me.
I've re-attached the error message I was getting when trying to do the diagnostics.
Moderator
Moderator
Message 10 of 14
Hi @MrJolly ,
Thanks for posting the test result screen grabs. I'll be happy to take a closer look at this for you. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
David
Kudos”
