mld73
Message 1 of 12
Youview remote code
Does anyone know a code which works with TECHNIKA LCD19DVDID-308 ?
11 REPLIES 11
Moderator
Moderator
Message 2 of 12
Re: Youview remote code
Hi @mld73,
If you take a look at How do I control my TV with my BT TV remote control?, it has the code 2448 listed for Telefunken.
Give that a try and let me know how you get on?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
HackneyMan
Message 3 of 12
Hi @Mid73
The Technika code is 0004 although just to confuse the issue there is also a code 0605 for Technica, but I believe the former is the code you want. I hope that helps.
HackneyMan
Moderator
Moderator
Message 4 of 12
Thanks @HackneyMan,
I totally misread that post Smiley Embarassed
Cheers
PaddyB
Kudos”
mld73
Message 5 of 12
Thanks for your reply but i'm afraid neither work
mld73
Message 6 of 12
Sorry, that doesn't work. Nor do HackneyMan's suggestions.
Moderator
Moderator
Message 7 of 12
@mild73 can you try resetting the remote then try again?
To reset your remote, hold down the ADDELETE SUB and BT PLAYER buttons at the same time, until the blue light flashes three times.
Community ModeratorNeilO
Kudos”
mld73
Message 8 of 12
Sorry. Still no good. It is an old set. Maybe it isn't possible.
Moderator
Moderator
Message 9 of 12
Hi @mid73
Found an article online that suggested that the company UMC may have something in the manufacturing of these Televisions try this code 3183.
Not sure if it will work but worth a go.
Cheers
Stuart
Community ModeratorStuartH
Kudos”
mld73
Message 10 of 12
Thanks for your suggestion. But no, that doesn't work either.
