Message 1 of 5
Youview remote won't connect to jvc tv
Just bought a new jvc LT-42C550, tried to connect my youview remote to it using the code 2788 but nothing and after a few minutes the control gives up and the blue like goes off.
anyone had this issue?
thanks.
4 REPLIES 4
BT TV Expert
Message 2 of 5
Re: Youview remote won't connect to jvc tv
Hello @George113355
I know my colleague helped someone before who discovered their JVC TV was a re-badged Vestel TV and using their code worked.
Kind regards,
Martin.
Message 3 of 5
I did read that and try the vestal code but with no success, I will try again though.
thanks
george
BT TV Expert
Message 4 of 5
Hello @George113355
Did you manage to get your remote working?
If you need any further assistance, please Private Message me your contact details and I will be in touch.
Kind regards,
Martin.
Message 5 of 5
I spoke to BT on the phenomenon and they sent me a new controller out (which is the same as my last one) but still no success.
Im not sure he w to private message you Martin.
thanks George
