Distinguished Guru
Message 1 of 5
Youview software update
Hi all
Decided to fire up the youview box that has not been switched on for a while.
Went to search for a film and got a system message to say needed a software update.
I went into settings and attempted this a couple of times.
If I check in device management it says I have the latest software installed, however if I check the software version on system info it says I am only at 23.14.0 last updated 2 Nov 2017.
How can I force the system to give me the latest version?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
4 REPLIES 4
Guru
Message 2 of 5
Re: Youview software update
Hi @Devon_Dave try these from the Youview Help pages.
Stew
Distinguished Guru
Distinguished Guru
Message 3 of 5
Hi @Devon_Dave
Couple of questions  as cannot easily find a look up to that software level.
which Youview box is it? Using the help key followed by I (info) button is one way of finding out if you are unsure ?
When you look at recordings on the box are they in lists or displayed in boxes/lists
do you have any recordings that you need to retain on the box  ?
is the box connected to your broadband and has a aerial connection ?
Probably a maintenance mode reset or a factory reset  over internet might be needed but could prove problematical if the current software is very old.
Recognised Expert
Message 4 of 5
Software check and update (if necessary) is usually performed on restart as part of factory reset
Distinguished Guru
Message 5 of 5
Cheers everyone. Got a few pointers.
Just remembered regarding the software level, I was on a couple of trials of youview so suspect that is trial software and probably is/was the latest.
I am sure I had to subscribe the box to another group that then gave me the trial software, so guess now have to revert which should give me the latest software
