listsd
Message 1 of 6
Youview software upgrade problems
Since the last software upgrade to my youview box, I have been suffering from the following problems:
  1. Catch up TV no longer working (simply won’t load programmes)
  2. No BBC red button available
  3. Intermittent transmission breaks from 1 or 2 seconds (blank screens) to several seconds (goes to “loading” screen)
  4. Intermittent pixelation even on strong signal channels
  5. Programme guide very slow to update/move within
  6. Very slow to start playing or delete recorded programs
I did report this via the official channels but got the usual "have you checked the cables" etc reply. Since this all happened immediately after the upgrade, I think that there's a very high chance it relates to the upgrade.
5 REPLIES 5
BT TV Expert
BT TV Expert
Message 2 of 6
Re: Youview software upgrade problems
Hello @listsd
Sorry to hear you are having some issues since the upgrade. If you would like to Private Message me your phone or account number, I'll be in touch to see how I can help.
In the meantime, I presume if you go to Settings > Software information > Update software there are no updates available to you?
Kind regards,
Martin.
Moderator
Moderator
Message 3 of 6
Hi @listsd Did you contact Martin about this and has the issue been fixed?
Cheers
John
listsd
Message 4 of 6
Yes, I have been in contact with Martin. We need to look at a few things so the problem is at present ongoing.
Stu
AdamD64
Newbie
Message 5 of 6
Hi Martin,
I have exactly the same issue - can you or someone else also help me?
Adam
BT TV Expert
BT TV Expert
Message 6 of 6
Hello @AdamD64
I'd be happy to help. Please Private Message your phone number or account number and I'll be in touch.
Kind regards,
Martin.
