occo85
Message 1 of 12
Yvm607
Hello I am having problems with my you view bt box, it keeps coming up with yvm607 error. Can anyone help
11 REPLIES 11
Moderator
Moderator
Message 2 of 12
Re: Yvm607
Hi @occo85,
Could you try the following steps  -
  1. Restart your TV and when the TV turns back on, then restart your YouView box
  2. Remove then re-insert your HDMI cable from both ends at your YouView box and TV, or AV Amplifier if you are using one
  3. If you have a SMART TV please make sure that the TV software is up to date
  4. If you’re connecting via an HDMI switch or AV amplifier make sure that the software for this is up to date. If it still fails try connecting directly to the TV
  5. If you still have the same problem, try a different HDMI cable and an alternative HDMI input in your TV
Give that ago and let me know how you got on?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
occo85
Message 3 of 12
Re: Yvm607
Thanks for the advice but still having problems with it. The picture comes on for 20 seconds with no sound then goes off again
rarmitage124
Recognised Expert
Message 4 of 12
Re: Yvm607
Do you have the problem when you access on demand players or the extra channels?
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
occo85
Message 5 of 12
Re: Yvm607
Yeh it's everything
rarmitage124
Recognised Expert
Message 6 of 12
Re: Yvm607
Just to confirm you have tried a new HDMI cable directly into the TV
Moderator
Moderator
Message 7 of 12
Re: Yvm607
@occo85 Did you manage to get this sorted? Please post back letting us know if you need any further help with this.
Community ModeratorNeilO
Kudos”Kudos”
occo85
Message 8 of 12
Re: Yvm607
Sorry I've been away on holiday. It's still not working after using a new hdmi cable
rarmitage124
Recognised Expert
Message 9 of 12
Re: Yvm607
Can you also confirm that you have tried putting the HDMI into a different port onto the TV?
occo85
Message 10 of 12
Re: Yvm607
Yeh I have done that also
