Distinguished Guru
Message 1 of 1
Zoom issue
Does anyone know of a problem resolution for the zoom function on the G4 box where the picture gets stuck in zoom mode  I am not talking about the EPG but when for example BBC1 is zoomed in and you fiddle about changing channels till one of the corrects itself and the pictures are back to normal. Usually C4 will bring it back in line. I have had this problem now on two G4 boxes. It doesn't happen on Sky or on my TV - is it an issue with a SonyTv?
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
