Message 1 of 3
aj900 error on login bt tv app iphone
i am having a problem logging in on the app on the iphone bt tv
keep gettin aj900 error with BTID
with email login i get aj931 error
i have spoken in the online chat with someone and got fobbed off 4 days ago
he went through some setps <me resetting my password etc> to no avail and said tech support would be in touch within 48 hours he also said the app should work as its listed as active on the account
can anyone help me login in to the BTTV app please
kind regards and seasons greetings
dave
2 REPLIES 2
Message 2 of 3
Re: aj900 error on login bt tv app iphone
Your BT ID is usually an email address - not to be confused with your account number.
Have you checked the guide to confirm your account is all set up correctly?
https://www.bt.com/help/tv/fix-a-problem/bt-tv-app/general/problems-logging-in-to-the-bt-tv-app-and-...
If that doesn't help, email me at tv.apps@bt.com including your BT account number in the email and I'll investigate.
Message 3 of 3
Hi @davepegram, did you get this resolved, or have you got in touch with the TV Apps team?
Cheers
John
