Message 1 of 5
trying to find out what bt tv package ive got cant get threw to bt and its not showing online
4 REPLIES 4
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: bt tv
Is is not showing  in My BT under the  Your Products  Tv &Sport section ?
Otherwise have you had a look at your last bill or if you have only recently ordered your order email as it would normally be stated there.
Message 3 of 5
Re: bt tv
ok thank you
Message 4 of 5
Re: bt tv
ok thank you
Message 5 of 5
Re: bt tv
got it sorted out thanks
