Message 1 of 5
channel on bt boxs
  on both off my  bt boxs i got 139 channels but on my now tv box i got 168 channels on  free to air so i got all the channels so wy can i just get  139 chonnels and not all the channels like i got on my noew tv box and i am on th same arrel
4 REPLIES 4
Message 2 of 5
Re: channel on bt boxs
The one that’s got less channels on it, have you tried retuning the channels on the box?
Recognised Expert
Message 3 of 5
@ken2222
I'd suspect that your signal strength on the YV box is perhaps a little low.
I reduced my signal strength when re-tuning recently to block out another region and when I went too far I was getting about the same number of channels as you instead of over 160.
Message 4 of 5
after all this time i retune my 400 bt boxs today and i got all my channels back with the same aerial  but not on the 2100 bt boxs in the bedroom .
Recognised Expert
Message 5 of 5
Compare the signal strengths on the 2 units, maybe the T2100 is losing more of the signal than the T4000.
Also atmospheric conditions can have more of an impact where the signal strength is lower than desirable.
