Newbie
Message 1 of 2
fault code
When trying to connect to any subscription channels or bt tv none is working i get fault code BTP-15005,IPC6007 i have tried reset on hub reset on set box and still gettong same faults any help gratefully recived
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: fault code
Hi @paulrwhit welcome to the forum and sorry you are getting these error codes. Are you still getting these errors? If so please contact the BT TV team on Live Chat and they will be able to help you.
cheers
John
