Message 1 of 2
internet channels shut down every day at 13.00 hrs
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: internet channels shut down every day at 13.00 hrs
@Johnpigott50 is your broadband connection dropping out at the same time? Do you get any error messages on the screen when this happens?
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
