jackson105
Message 1 of 11
mini connectors
Hi new to forums so be gentle with me!. My question is i have fitted two BT mini connectors to run my BT TV box all working great. i can see that thare are two Ethernet sockets on each plugin connector is it possible to use the spare socket on the tv box end to connect another device?.
 Thanks jack.
10 REPLIES 10
Message 2 of 11
Re: mini connectors
Yes, of course you can Smiley Happy
jackson105
Message 3 of 11
Re: mini connectors
thanks for message do i need to connect the router end spare port on mini connector to router as well.
Zombie
Expert
Message 4 of 11
Re: mini connectors
Hi @jackson105 no that's not necessary,  the mini connector nearest to the hub just needs one ethernet cable, the other connector you use for bt tv just use an extra ethernet cable on that connector to your tv or another device. That's what I do they work a treat.
jackson105
Message 5 of 11
Re: mini connectors
hi connected tablet into spare port on TV Box end mini connector and yes it does work but the upload speed is 5.1 but the download speed is 0.7mbs. on wireless these speeds are 5.1 upload and 7.1 download any suggestions please. my desk top which is ethernet 5.7 upload and 41.33 download.
 thanks.
siteguru
Expert
Message 6 of 11
Re: mini connectors
Are the two ends (router end and TV end) on different ring main circuits? (e.g. router downstairs, TV upstairs).
Have you plugged either mini connector into a power extension strip? (Some strips have protection circuitry that effectively kills networking over the power lines).
Ian
http://www.siteguru.co.uk/be/ADSL2PlusForDummies.pdf - Having ADSL issues? Then read this PDF
Please don't click the star beside my name - too many stars makes you look like a swot!
jackson105
Message 7 of 11
Re: mini connectors
Hi no both mini connectors downstairs but at opposite ends of house but pluged directly into wall sockets.
 will check if there is more than one ring circuit in morning.
 Thanks for reply hope i can now get to bottom of problem?
jackson105
Message 8 of 11
Re: mini connectors
just to add checked rings and they are both on same ring main?
benwiddowson
Message 9 of 11
Re: mini connectors
I created an additional socket in my kitchen taking a spur off an existing socket in the room. This new socket I've found powerline adapters just don't function properly while the rest of the house is fine. Any chance you've got somthing similar?
jackson105
Message 10 of 11
Re: mini connectors
hi its possible as the house is timber framed and all wiring goes up into ceiling and the around house and the up and down to every socket so anything possible, so have purchased a long ethernet cable and going to run that.
thanks
