frank64
Newbie
Message 1 of 3
my normal tv and freeview channels won't work only channels that needs Wi-Fi work
dose anybody now what's up with my tv all my normal channels and freeview channels won't work keeps saying that there is a problem with the tv aerial but i have checked all the wires and they are fine tried retunning the bt box but it only found 26 channels and none of them are freeview or bbc,itv ect
2 REPLIES 2
Message 2 of 3
Re: my normal tv and freeview channels won't work only channels that needs Wi-Fi work
Welcome to this user forum. @frank64
Check your signal quality in the settings menu.
  1. Bring up the menu with your remote
  2. Select Settings
  3. Go to the Signal & Connection area and select Signal Quality
Moderator
Moderator
Message 3 of 3
Hi @frank64  did you manage to get your TV channels working ok?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
