mabrookes
Message 1 of 7
netflix wont login
I have a netflix account already, and used to use it with talktalk youview all the time.
Since going to BT we have been busy, and also moved house, so havent really used the TV much but have now tried to use netflix over the christmas period. Everytime I try and login it just says there is no account associated with that email.
I have deleted and carefully typed back in both email and password over and over, several different times, and each time it is the same. It works perfectly on 2 laptops and 2 phones and I have logged out and back into all of them to make sure.
The problem only happens on BT youview, is anyone else having/had this problem?
6 REPLIES 6
siteguru
Expert
Message 2 of 7
Re: netflix wont login
No. My Netflix account works fine on my BT YV box.
Ian
http://www.siteguru.co.uk/be/ADSL2PlusForDummies.pdf - Having ADSL issues? Then read this PDF
Please don't click the star beside my name - too many stars makes you look like a swot!
Seamaster
Message 3 of 7
Same here, works fine across all my devices including BT YouView.
You could try resetting the YouView box, I suppose.
barringtonk
Message 4 of 7
Had exactly the same problem.
I solved it by accessing the hidden menu.
1. Open Netflix app
2. On remote press up up down down left right left right up up up up up up
That should display the hidden menu.
Select log out
Then log back in again
Worked for me!
GarethW
Expert
Message 5 of 7
Yeah, it was the solution above that worked for me too.
Don't choose to log out of all devices though.
mabrookes
Message 6 of 7
Hey, thanks for the reply - sorry for the delay I was busy and havent had chance to respond.
That worked for me. I didnt want to reset the box at the moment as there are recorded things to watch still that I never have time for so thanks.
Clair
Newbie
Message 7 of 7
I can't thank you enough. Have now been able to fix the problem using the hidden code. Don't suppose you know the winning lottery numbers? Thanks
