Ronof9
Message 1 of 2
no longer have 'Sport' as an option when hitting the blus 'Y' button, then up
Youview box froze the night b4 last, I no longer have 'Sport' as an option when hitting the blus 'Y' button, then up -
BT Sport tonight when The Champions League was on, and now BBC1,2 have dissappeared.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: no longer have 'Sport' as an option when hitting the blus 'Y' button, then up
@Ronof9 I'm sorry to see you're having problems with your BT TV service. If you get in touch with the TV helpdesk on this link they'll be able to help.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
