pumpkin0193
Message 1 of 4
no sound on BT youview
Keep having no sound on Youview, have to switch power off and on to unit , then sound is ok, sound is not off on youview controller. Sound ok on terrestrial channels on TV. This is really anoying  as it takes youview time to restart. If the youview box is at fault, who changes it?
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: no sound on BT youview
I can't be certain but I think I'm right in saying that if the box is faulty and you're in contract, or if the box is less than 12 months old then BT will replace FOC. The same applies (I think) if you are out of contract but are willing to sign up to a new one (contract)
Gemma_P
BT TV Expert
Message 3 of 4
Hi @pumpkin0193 sorry to hear you are having problems with your Youview box, if you PM me your details I can arrange for a replacement box to be sent to you. Thank you,
pumpkin0193
Message 4 of 4
thanks Gemma, new box on its way>
