Billyfitzs1983
Message 1 of 16
only freeview
since signing up for bt and having my bt box  for over a month ive been unable to use it. its all connected but can only get freeview channels even tho im paying £110 per month for the full package. i keep getting error code IPC6015 .
i was also sold a bt package on the promise of a xbox as a gift and after 40 days theres been no mention of that either.
due to the current coronavirus pandemic i am happy to let the xbox slide for now as i know customer services are busy.
however i am not happy paying well over £100 a month for a package i am unable to use.
can anybody help ?
thanks
15 REPLIES 15
-Richie-
Guru
Message 2 of 16
Re: only freeview
Have you connected the Youview box to your hub ? the Youview box would of included a 10 meter ethernet cable, If you're getting freeview channels it means the aerial is connected ok, your other content is delivered by internet.
Try watching BBC iPlaer or ITVplayer and 4od, they also require internet connection to work.
Billyfitzs1983
Message 3 of 16
Re: only freeview
hi thanks for reply
the apps are not connecting
i connected all leads and cables
however in settings
on the bt box it says its all connected to the hub fine and is picking up connection
thanks
Anonymous
Not applicable
Message 4 of 16
Re: only freeview
Have you looked here for help
Billyfitzs1983
Message 5 of 16
Re: only freeview
hi thanks for your message
yes i have followed all them steps and still nothing
Anonymous
Not applicable
Message 6 of 16
Re: only freeview
Apart from the error code, is there any other message?
Billyfitzs1983
Message 7 of 16
Re: only freeview
hi thanks for your reply
i just keep getting this error code/ on all the suscription channels
ipc6015
there is a problem with your broadband
check connection between box and router.
but when i go to settings
its all connected correct and its showing me its fully connected to broadband
Andy005
Recognised Expert
Message 8 of 16
Re: only freeview
Hi @Billyfitzs1983
If you haven't already done so it might be worth doing a factory reset of your home hub and another ethernet port.
Anonymous
Not applicable
Message 9 of 16
Re: only freeview
Try www.bt.com/help/home/faults
If that doesn't work then you might have to ring them
Billyfitzs1983
Message 10 of 16
Re: only freeview
hi Andy thanks for suggestion
and thanks for taking time out of your day to reply
i am thankfull.
in regards to your suggestion i have already done this twice
even moving all leads and replacing them too.
its still showing as connected to broadband
still letting me access the freeview channels
with no problem.
however wont let me use bt player or access the suscription channels and shows an error message
as i currently suscribe to the vip package most should be active.
thanks
