I have 2 youview recorder boxes and they both have the same `fault`.If i am watching a recorded program and don`t finish it straight away and turn the box off when i come back later to continue watching the program it has jumped forward 3 or 4 minutes . Does anybody know of a way to stop this or is it a general fault with all boxes/ Any advice would be welcome!!
How are you stopping the recording playback ?
@ffreddwrote:...........If i am watching a recorded program and don`t finish it straight away and turn the box off.................
When you say "turn the box off" do you mean by the switch on the box, putting it into standby or removing the power altogether?
I also have two boxes and if I don't have time to watch a recording from start to end then I firstly stop playback then put my box in to standby and I've never experienced this problem
Hi and thanks for your reply. Sometimes i press`back` and other times the button with the white square between the record button and Fast forward.
I stop it by either pressing `back` or the button with the white square between the record button and fast forward. Then i turn the recorder off by using the on/off button on the remote !!
The button with the white square is the correct one to stop playback, I've never tried pressing the back button whilst viewing a recording so can't comment. Try to ensure you always use the stop button (the one with the white square) and see if that resolves your problem
@ffreddwrote:I stop it by either pressing `back` or the button with the white square between the record button and fast forward. Then i turn the recorder off by using the on/off button on the remote !!
The on/off button on the remote doesn't switch the box off, it places it into standby. The difference being that the box still consumes power during standby (albeit a very small amount) and thus the box comes on immediately when you bring it out of standby.
yeah,i understand that.It`s just the way i worded it. Thanks for taking the time to reply.Regards
