Capt_Mike
Message 1 of 5
powerline adapters and buffering during catch up
I have a BT infinity connection, Smart Hub and Humax Youview box. The Youview box is connected to the Hub via Netgear powerline adapters. The problem that I'm having is prolonged buffering when using BBC iPlayer to catch-up.
If I go to the Smart Hub control panel and view the Humax data, it shows 953 Up and 37.52 Down. Is the latter too slow due to the powerline adapters and the cause of the buffering. If so I would be grateful for advice on suitable powerline adapters and replacements.
4 REPLIES 4
robert1997
Message 2 of 5
Re: powerline adapters and buffering during catch up
Your speeds are far above what you require so no problems there. I also had issues with BBC iplayer and it was suggested to me to change to iplayer beta. You can do that from within settings when in the iplayer. It has helped me so hopefully would also work for you.
Capt_Mike
Message 3 of 5
Thank you. I shall give that a try
Capt_Mike
Message 4 of 5
Just watched a 1 hour programme without any sign of buffering. Thank you again. IPlayer beta seems to have solved it
robert1997
Message 5 of 5
Good to hear @Capt_Mike. Works much better for me too.
