Moderator
Moderator
Message 11 of 13
Re: problem with Gold HD record
Hi @DazzaS83 that's great, I'm glad that worked for you 😀
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
peter1uk
Message 12 of 13
Has worked for me as well.
Moderator
Moderator
Message 13 of 13
Hi @peter1uk  ah great, thanks for letting me know 👍
Kudos”Kudos”
