Distinguished Guru
Distinguished Guru
Message 11 of 51
Re: recording radio
An update to this problem was published on the Youview Community forum today by their Community Manager  (Sarah)
https://community.youview.com/youview/discussion/comment/18995176#Comment_18995176
If i inteprete it correctly the radio recordings have probably been successfully recorded but the current issue occurs during  the playback. Appears to occur on Youview  software 31.24.0.
wepxc11
Message 12 of 51
Re: recording radio
thank you for your help. I will have to await the next upgrade I supose
Stevek1311
Expert
Message 13 of 51
Re: recording radio
Why is this marked 'solved' when it isn't?
YouView have not included a fix to this in their last July 23 update as that focussed on only one issue.   Until they do the problem is very much still there
Distinguished Guru
Distinguished Guru
Message 14 of 51
Re: recording radio
@Stevek1311  The original poster  marked the post  response as an accepted solution on 3 July to their thread.
Stevek1311
Expert
Message 15 of 51
Re: recording radio
Thanks for the explanation, apologies for venting frustration at you/your post
All I can really say is they need to learn the meaning of the word 'solved'
Jezza60
Message 16 of 51
Re: recording radio
Does anyone have an idea when the software will be updated so I can play my Hancocks half hour, goon shows etc which currently have no sound? Thanks
Jezza60
Message 17 of 51
Re: recording radio
Hello, I have a backlog of Hancocks half hour, goon shows etc which I can't listen to as there is no sound. Any idea when the software update will fix this? It's been going on for weeks now. Cheers, Jezza
gomezz
Recognised Expert
Message 18 of 51
Re: recording radio
Are they available on iPlayer Radio to listen to?
Jezza60
Message 19 of 51
Re: recording radio
No, it appears not. Waiting for BT to post an update!
Distinguished Guru
Distinguished Guru
Message 20 of 51
Re: recording radio
If you try unplugging and plugging back in the HDMI  it can sometimes help restore the sound on playback of  radio recordings.
