Jezza60
Message 21 of 51
Re: recording radio
Thanks for the suggestion, but no joy. All I get when I stop playing the recording is, pardon me, a brief farty sound.
BT, plesae update on what the problem is and date of resolution. I'm paying for a faulty service.
Stevek1311
Expert
Message 22 of 51
Re: recording radio
Don't hold your breath,  BT have never ever publicly criticised YouView and since there's nothing BT can say on this that is positive about YouView or isn't likely to look like a promise YouView fail to deliver on then silence must be very tempting
I suspect in private a somewhat "not another foul up" conversation has taken place.  Well at least it should have
Waddo2004
Message 23 of 51
recording radio ( No sound )
My friend had this issue and he recorded the radio programme and came across a temp fix albeit its not right.
Start your radio recording playing , there will be no sound. Hit the power button on the remote to switch off the bt box.
Then power up the box by pressing the power button again and hey presto, there is sound playing from the recorded radio programme......
Strange one and he came across it as pure luck but hopefully that will help some of you until BT release a software update to fix this bug.
All the best, hope this works for you guys !!
Jezza60
Message 24 of 51
Re: recording radio ( No sound )
Thanks, that works. Quite remarkable.
wepxc11
Message 25 of 51
works for me thank you
Stevek1311
Expert
Message 26 of 51
And me too.  Thanks Waddo2004
Waddo2004
Message 27 of 51
My pleasure , pleased it’s working until this issue is fixed properly
gomezz
Recognised Expert
Message 28 of 51
Interesting! I wonder if this works for the loss of audio after FF of an internet recording problem too?
gomezz
Recognised Expert
Message 29 of 51
I can confirm this tip works for radio recording over an optical connection to an AV amp.
I can also confirm it does not work for the other issue with FF and internet recordings.
Rodney1
Message 30 of 51
Having had my “Youview” box changed twice because we lost the sound on Radio recordings. It was discovered that is was the latest software upgrade that was causing the problem. So now with my third box I was able to listen to my radio recordings, but each time it is changed I lose all my recordings. So, what do “Youview” go and do? Send me the new software even though they know there is a problem with it. So now I’m back to square one. When are you going to fix this problem “Youview” ?
