ZReked
Newbie
Message 1 of 3
tp-link Archer VR400 IPC6023
Keep getting message IPC6023 on my youview for my BT TV Subscription channels can anyone help?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: tp-link Archer VR400 IPC6023
@ZReked You'll need to ensure that you've set up the multicast settings on your router to enable the BT TV channels to work.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Dode
Message 3 of 3
I haven't needed to set up multicast on the VR400. It works fine with BTSport.
