londonman
Message 1 of 5
you view box if cancel tv
does any part of the you view box work if you cancel your tv subscription ?
4 REPLIES 4
Colin_London
Recognised Expert
Message 2 of 5
Re: you view box if cancel tv
Yes - everything except the BT TV Extra & Sport Channels and BT Player will still work. Any recordings made of extra channels however will stop working when your subscription stops.
TimCurtis
Recognised Expert
Message 3 of 5
@londonman
And  just ignore any requests to return your Youview box as it's yours to keep.
Colin_London
Recognised Expert
Message 4 of 5
Don’t you have to have had it over 12 months to be able to keep it? (I have had mine 4 1/2 years so will be keeping mine)
TimCurtis
Recognised Expert
Message 5 of 5
Once it's delivered it's yours but finishing a contract early will involve cancellation charges which I assume would be higher if in the initial contract period when the box was supplied
