rodW
Message 1 of 4
youview TV Box standby problem
My Youview Box works very well except for a very slow to restart. I followed on screen advice to select smart standby mode but when I do this, the box always resets to automatic standby 3 hr. Please advise
3 REPLIES 3
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: youview TV Box standby problem
Hi @rodW welcome to the community.
The Automatic Standby  and  Standby Mode  plus the Start Deep Sleep and End Deep Sleep are all controlled within
Youview >Settings>Box Management >Power & Standby
so if have you set Standby Mode to SMART  you can  select the Automatic Standby  line which you seem to have currently at 3 hours and change it to another value eg 2 , 4 or 12 hours.
rodW
Message 3 of 4
Many thanks for your advice. I hadn't realised that each standby mode had a further level of configuration and that smart mode was already in operation. I feel the software designer(s) confuse users by showing the message Use smartmode for faster startup  when YouView is booting up even when it is in operation!
manchester10
Message 4 of 4
i have exactly the same problem - but no reply!
