fatman_stu
Message 1 of 3
youview and usage
Hi, i'm curently with sky for my broadband and want to swap to bt so I get the sports channels. I also want the youview box as a way to record/ stream tv, I can currently do this on the ps3 but prefer being able to record. My main question is does streaming on the youview (iplayer, itv etc.) box use up your allowance.
I am thinking of going with infinity 1 with 40 gig allowance as a means to keep the cost down. If I don't need to worry about streaming I think I should keep under the allowance easy enough.
I have tried asking the bt reps online but no-one will answer without me ringing up
2 REPLIES 2
GarethW
Expert
Message 2 of 3
Re: youview and usage
YouView *doesn't* count towards your allowance.
fatman_stu
Message 3 of 3
Thank you, thats all I needed the reps to say
