bazaar1
Message 1 of 4
youview box scrolling through channels
flipping youview just keeps scrolling through the chammels without stopping, just spoke at length to someone in India, ( Nice one BT), cant get Engineer for 2 weeks, so stuck without youview ( That I am paying for ), has anyone got any experience in claiming back from BT for loss, also for breach of contract?
3 REPLIES 3
ChrisC
Message 2 of 4
Re: youview box scrolling through channels
By any chance are you using a Samsung TV on HDMI? There have been reports of some Samsung TV's sending commands down the wire that confuse the YouView box. It's a problem with the CEC feature (called Anynet+) on Samsung devices so try turning this off in the menu ref: http://en.wikipedia.org/wiki/HDMI#CEC
dwrighty
Message 3 of 4
Mine is doing exactly the same. If it isn't the channels cycling it's the volume.
Either a hard power cycle or a software reset via maintenance mode seems to fix it short-term.
Had to do the above at least seven times today. Getting really fed up with it now.
I do have a Samsung TV but AnyNet+ is turned off.
- D
cridds
Newbie
Message 4 of 4
Mine likes to turn Audio Description on. Go a Samsung too with Anynet turned off. Currently waiting for a second engineer visit (2week wait) as the box also freezes has pic but no sound and remote + box buttons don't work. This happens intermittantly. only had it 6weeks and had 3 weeks usage out of it!
