insignia1
Newbie
Message 1 of 2
youview plus box unable to connect to router
had to power down my youview plus box today, i am also using poerline adapters to get the internet in my living room.  since poering everything back up, i cannot get the data light on the powerline adapters.  Have reset the homehub 5 and still no data light on the adapters.
As a result i have only got freeview channels and not the internet channels.  could it be the powerline adapters have gone faulty.  any help would be appreciated.
many thank.  i wait for some suggestions.
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: youview plus box unable to connect to router
if the powerline adaptors have not synced then that will be the issue.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
