theandrews
Newbie
Message 1 of 4
yvm105 error with my new youview box
My father just received his youview box today and the above error appeared when I tried yo use bbc iplayer. I have tried all the other on demand options and they work successfully.  I tried the suggestion mentioned on a previous message by switching off and counting to 10 then going into device management.  Still not working. Please help.
3 REPLIES 3
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: yvm105 error with my new youview box
Interesting that currently the BBC has this message
http://iplayerhelp.external.bbc.co.uk/tv/connected/youview-error-yvm105
YouView – Error message YVM105
We’re aware of an issue where some people can’t access BBC iPlayer on their YouView set-top-box and see the error message “YVM 105”.
If this happens to you, try restarting your YouView box.
If restarting doesn’t solve the problem, contact YouView Viewer Support to perform a Maintenance Mode Recovery. This process involves a few steps, so we strongly recommend you don’t try it on your own.
I've raised a question on the Youview community forum
https://community.youview.com/youview/topics/bbc-iplayer-problem-on-youview
Meanwhile its probably worth checking for any software updates or Player updates on your youview box as new boxes may require a series of updates to bring them fully up to date.
 eg
  1. Press the YouView button  on your  remote
  2. Select Settings
  3. Select Device Management
  4. Select Software Update
  5. Select Get Update
  2. Select Settings
  4. Select Update On Demand Players
  5. Select Check Now
  6. Select Finish
& possibly doing a further power off and restart afterwards.
BT TV Expert
BT TV Expert
Message 3 of 4
Thanks for reporting,
We have raised an incident with youview and the BBC.
Cheers
Steve
BT TV Expert
BT TV Expert
Message 4 of 4
This should now be resolved. Thanks for your patience.
Steve
