Message 1 of 2
Addressguard
I was just checking changing some passwords.
Not used my Addressguard addresses for some time so tested one, the message came up on the Webmail page but can't find my note of my password for it and can't find the page where you set up Addressguard password - seems to use the same for all Addressguard addresses.
How do you set it or get a password reminder.
I made the mistake of following the Yahoo link to set up privacy.  One page for just about every company advertising online but most not responding so you cannot set for no adverts.  Most of the others took you to a page with several screenfuls of legalise about what a wonderful company they are and how they value your privacy but nowhere to turn off adverts or cookies!
MB
Tags (2)
1 REPLY 1
Message 2 of 2
Re: Addressguard
Solved!
They are discontinuing ADDRESSGUARD, you can no longer send from an ADDRESSGUARD address and they will be removed in the new year.
http://bt.custhelp.com/app/answers/detail/a_id/48151/related/1
MB
