Message 1 of 4
Advice on Smarthub 2, black disks and Sky
After problems with our BT broadband and WiFi a BT manager suggested we switch to the Smarthub 2 and black WiFi disks.
When we set up Sky Q I remember the advice being to split the 2.4 and 5 GHz frequencies on BT HH router and I’ve read that the new Smarthub 2 can’t split these WiFi frequencies.
Can anyone advise if the Smarthub 2 and black whole home WiFi disks will work with Sky Q?  We don’t have Sky broadband and use BT.
Also, will the Smarthub 2 not splitting frequencies cause problems with other home WiFi connected devices?
Thanks for any advice.
3 REPLIES 3
Message 2 of 4
Re: Advice on Smarthub 2, black disks and Sky
Hi @Rotarua674 ,
Only the Sky router connects to Sky Q at 5Ghz, with any other router you have to use 2.4Ghz.
Suggest you check things like this on the Sky forum, here :- https://helpforum.sky.com/
Message 3 of 4
Thanks for your advice.
Message 4 of 4
I’ve got the BT SmartHub 2 and two black Complete WiFi discs and Sky Q. Everything works a charm. I have turned off Smart Setup on the hub as some report that can cause problems if left enabled.
