Hi.
I'm having a strange problem where some apps on my Android devices can't connect properly to internet services. For example FlightRadar24 to track aircraft; the app will load the basic interface and download the map, but it then just shows the spinning wheel and displays no aircraft. If I stop WIFI and use 3/4G it will display the aircraft. Various other apps show problems when on WIFI, typically taking about 30 seconds to fully start, when it takes 2 seconds on 3/4G.
It feels like a routing table or DNS issue; some requests being mis-directed and timing out. I have tried on other WIFI's and all works perfectly, so I don't think it is a problem with the phone.
Equipment: Samsung S20, BT Whole Home WiFi, BT Smart Hub
It's frustrating that I need to keep turning WIFI off to get my phone to connect properly!
Any ideas gratefully received.. thanks
Simon
Solved! Go to Solution.
Try turning off smart setup on the hub
also check web protect is off in MYBT
