What has happened to the BCC option in the new BT MAIL and how do I now hide addresses of those copied in to an email?
Solved! Go to Solution.
If you click on the compose button this will open a new email. Depending on your screen size the BCC button is either at the far right of the "To" address box or if not there, if you click on the "To" button you will be given a drop down box with the CC and BCC options.
Nothing has happened to it, the option is still there.
