Message 861 of 1,492
Re: BT Fibre 900 Upgrade / Smart Hub 2 upload throttling..... Update
Thanks StuartH,
Replied PM with details.
Message 862 of 1,492
Hi @StuartH
Sorry to jump in on this, is it possible to take a look at mine also?
Im experiencing the same issue.
Message 863 of 1,492
Hi @mrtpitydafool and welcome.
I'll be happy to take a look at this for you. I'll drop you a private message now so you can get in touch.
Cheers
David
Message 864 of 1,492
Hi Paddy - i hope you can help - my SH2 just updated it's firmware yesterday to v0.24.04.11017-BT and it has capped my upload to 50mbps. Im on the 900 package. Can you also send me details on how to fix please?
Message 865 of 1,492
Hi @jaforce23 and thanks for posting.
I'm sure I'll be able to help with this. I'll drop you a private message now so you can get in touch.
Cheers
David
Message 866 of 1,492
@DavidM  - I was hoping you might be able to help me as well?
I’m on full fibre 900 and only really achieving 400/500 tops even when connected with a PC directly into the ONT. I’ve tried raising it through support but not been very successful getting help with the issue.
I think there is an issue but I can’t diagnose it
Message 867 of 1,492
Hi there, I am on the 500mb/70mb package. After a recent upgrade to the firmware in my router to v0.24.04.11017-BT my upload speeds are now capped at 50mb (plus download doesn’t seem as fast as it was - I would typically get over 400mb, but rarely get above 250mb now).
I have tried to do the speedcheck via Bt site (and app) but this has never worked for me, so I was using Speedtest.net as a reference.
Can you please look in to what is causing the reduced speeds in my connection. If you send PM, I can confirm details.
Steve
Message 868 of 1,492
EDIT
Issue now resolved
Message 869 of 1,492
@DavidM Are you able to assist with resolving the speed issue.
Steve
Message 870 of 1,492
Hi @Sventhebrit,
Thanks for posting. I'm sure we can get this sorted for you. I'll drop you a private message now so you can get in touch.
Cheers
David
