Message 751 of 1,492
Re: BT Fibre 900 Upgrade / Smart Hub 2 upload throttling..... Update
I believe it relates to those using the smart hub 2 only.
BT Full Fibre 900
Message 752 of 1,492
Sorry should have mentioned i do not use the smart hub now.. not within the last few months
but the  last 3+ months i have had no issue with upload speeds.
download speeds go around 910-970 on download rarely dipping below that (for now anyway lol)
When first got FTTP installed the upload was capped to 50mb but this sorted itself out within half hour on the smarthub and never had the problem sinse.
Reason for switching routers was for better wifi speed
I am not currently using netgear rax80
Message 753 of 1,492
Thanks to both @Barneyabz and @jamie1985
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 754 of 1,492
No problem @busterboy1
Message 755 of 1,492
Jamie, does the smart hub 2 not provide the “modem” functionality or is that done by the fibre ONT? I’ve got a Netgear Orbi system but didnt think that could be used instead of the smart hub 2, just thought it was in addition to?
Any thoughts?
Cheers
Mark
Message 756 of 1,492
Big thanks to the moderators for their help, my upload is now at 110mb 🙂
Keep up the great work!
Mark
Message 757 of 1,492
Hey m4rks
Should work fine with netgear orbi kit.. i assume they all have ethernet so should be able to link the first one to them all.
All i had to do with my netgear router was enter the bt address and pass and worked right away.
with my smarthub 2 i was getting max speed on the idm of around 102.00 MBps which is around 800mb
(still crazy fast)
but using netgear my speeds go around 118-122MBps so speeds of around 970
wifi 6 speeds are go around 590-740
Message 758 of 1,492
@m4rks  the ONT is the modem. Having the SH2 with the Orbi Router in bridge mode is fine. I did that myself for some time with the RBK50. However, you can remove the SH2 and connect the Orbi directly to the ONT but you'll need to change the Orbi mode  from bridge to router.
Message 759 of 1,492
@jamie1985 What Netgear router are you using to get those speeds?
I was thinking of switching out the Smart Hub 2 for something else as I'm getting ports dropping connection when I have auto speed negotiation turned on.
Message 760 of 1,492
Think I might still need the SH2 as I’ve heard  SkyQ doesn’t like working with Orbi so currently have that hardwired directly into the SH2 then everything else off the Orbi
