Message 1 of 4
BT Hub 3.0 + ethernet cable buffering/connection problems
using BT hub 3.0 and ethernet cable it works ok with tv in Netflix but constant buffering in BBC I player then reverts to normal tv. Is this a problem with ethernet connection in hub. Worked ok on Wi fi but tv had to be moved a few yards away beyond WI FI range but surely should work with ethernet cable.
3 REPLIES 3
Message 2 of 4
Re: BT Hub 3.0 + ethernet cable buffering/connection problems
Hi @Joannemar  sorry you are experiencing a problem with buffering when connected via Ethernet. Is it possible for you to test with another Ethernet cable to eliminate that as the cause?
cheers
John
Message 3 of 4
Thank you but not possible and why would ethernet cable work for Netflix and not I player.
Message 4 of 4
Moved TV nearer to hub and tried with another ethernet cable still didn't work but spoke to BT and they are sending another hub. Thanks for your response
